Calling WORK Wheel Owners / Spacer Users
Old Oct 30, 2010 | 11:16 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by konxeptionz
I just assumed that since WORK wheels are also forged, then the set up would be similar to how the OEM 19's were.
T1S's have a cast center....
Old Oct 30, 2010 | 11:53 PM
erklep's Avatar
Originally Posted by psycobusa
maybe this is a stupid question but can't you just bore out a hole on the back of your rim where the fifth hole is supposed to be?
i called it
Old Oct 31, 2010 | 01:46 AM
mikegg35's Avatar
I got the ichiba 10mm spacers with extended lugs separate, its more time consuming to take off the old lugs, but at the end it pays off.
Old Oct 31, 2010 | 03:23 AM
thenameistuan's Avatar
Well Son this is why you shouidlve bought Project Kic spacers ;D
Old Oct 31, 2010 | 05:39 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Not about to bore out a hole on a set of wheels that I spent 3k on. I hope you did the proper research when you ordered your wheels so you don't run into the same issue as me. Save you some time, some money, and a headache.
Originally Posted by erklep
true. son, you could run 25mm. the lugs come flush with those and you dont need the holes in the wheel. you might need to play with camber and fender work then though. i had my works bolts up with my 25mm spacers when i first put them on just for shts and giggles and they bolted right up
Yea when I had 25mm V2's on my Rays, I noticed that they were flush so that was never an issue with it. I honestly don't want to run that big of a spacer just to be able to have the back of the of my wheel face sit flush with the spacer itself. It would put me at a -10 all around and I know with that offset, I'd have to run -3 degrees of camber, give or take .5 degrees.
I like the whole stance scene and all, but the -10 offset is just too aggressive for me.
I'm just going to find a set of 15mm V1's and call it a day. I really only need to run spacers for my front A-Disc face, but I don't want my front to be closer to flush then my rears. It is the reason why I'm trying to match it all around. If I can get away with running a 10mm spacer to clear a set of Brembos on my A-Disc face, then I will do that.
I now stand corrected in my first assumption. Thanks for the info.
Alex, in the end it isn't the kind of spacer I used. I would have run into the same issue if I bought the bolt on hub Project Kic spacers as well. The issue isn't the quality of the spacer, the issue is that my wheel doesn't allow me to run a V2 style spacer because there are only 4/5 holes on the back of my wheel face that lets me do it.
Old Oct 31, 2010 | 12:59 PM
psycobusa's Avatar
[QUOTE=konxeptionz;5452022]Not about to bore out a hole on a set of wheels that I spent 3k on. I hope you did the proper research when you ordered your wheels so you don't run into the same issue as me. Save you some time, some money, and a headache.
when i ordered my wheels, i let them know i was planning on running oem brembos in the future and that's why i was ordering rdisk for the front. Work Wheels ended up calling a couple of days later and said i should get the tdisk instead just to be on the safe side.
i cant be positive because im not there to see your wheel in person and how the backside sits against the spacer but from the pics it looks like that small hole on the back of your rim where the 5th hole should be would fit right over the oem stud if it was bored a couple of mm or so. i cant see it doing any harm to the rim but im no wheel designer so who knows aside from Work.
i guess the next less expensive thing to do would be to dremil that 1 stud flush on each hub. if you ever wanted to remove the spacers or put on your oem wheels you would only need to buy and replace 4 studs.
Old Oct 31, 2010 | 03:11 PM
XiN's Avatar
XiN
Itasha Coupe
^^ Again, taking a dremel to the hole to make the spacer fit is NOT an option. I will NOT go with a cheap and crappy route to make a spacer fit when there is a proper way to do it.
Old Oct 31, 2010 | 04:11 PM
erklep's Avatar
hes saying to dremel the stud down. but either way, im with you. dont drill or cut
Old Oct 31, 2010 | 07:14 PM
XiN's Avatar
XiN
Itasha Coupe
He suggested both, actually, Eric. But I am glad that you and I agree that cutting / drilling / dremelling is a bad idea.
I don't mind losing a bit of money on my own mistake, since it was my fault entirely for not checking ahead of time and just assuming. It can be made right by just ordering the correct style spacer.
In the end, I just want it done right and not to cut any corners.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
