what size spacers
Old Nov 8, 2010 | 08:37 PM
ShaneH85's Avatar
what size spacers
i have factory ride height and forged rays 19 factory wheels. What size spacer do i need to just set the back tire flush with the fender? that sunken in look is driving me nutts and im not putting my new suspension or wheels on until after winter.
Old Nov 8, 2010 | 08:44 PM
walshtj's Avatar
15 for rears should be fine.
Old Nov 8, 2010 | 08:46 PM
ShaneH85's Avatar
cool thanks man, around march next year im going to put on my coilovers to lower the car and i have a set of work t1s, they should clear my brembos, correct?
Old Nov 8, 2010 | 09:29 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
I'm fairly certain in order to make it actually flush you need 25 MM in the rear and 15 in the front. No way 15 MM will get it flush for the rear, atleast 20 MM. You can eye it up.
Old Nov 8, 2010 | 09:48 PM
kday's Avatar
or 25's all around
Old Nov 8, 2010 | 10:02 PM
jwolfpk's Avatar
I got 20/25mm the front is pretty much perfect nd in the back you'll get alittle negative camber..makes the car look soo much better though
Old Nov 8, 2010 | 10:09 PM
breezerboat's Avatar
nevermind on my post. I got it.
Old Nov 8, 2010 | 10:24 PM
anyone got pictures with stock 19s that have spacers.
Old Nov 9, 2010 | 12:06 AM
Silencer_0's Avatar
20mm spacers all around, back when I was stock-ish . I'd recommend 20/25 or 25 all around. Really depends on your drop too, I already had coilovers at this point.
Old Nov 9, 2010 | 12:16 AM
Xet's Avatar
Xet
Just plain wrong.
OP you should really search, if you did you would know a flush setup is 25/30
Old Nov 9, 2010 | 08:05 AM
ShaneH85's Avatar
this is exactly what I'm looking for, car looks great in the pic man. I am still at factory ride height, i just recently ordered my tein flex coils and i already have work t1s. Just waiting until after i get some door dings taken out and the warranty work done (oil in #6). thought about just waiting til after winter all together, but i just can not stand that sunken in look until then. thanks for all the help, glad i didn't go with the first response.
Old Nov 9, 2010 | 09:50 AM
Xet's Avatar
Xet
Here was my car 25mm all around but dropped on coils.
I would at least recommend 25mm all around, but since you are stock height I would do 25/30 like I recommended before for a better flush fit.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
