Fitment question
Old Jan 5, 2011 | 11:31 AM
Sp33dY's Avatar
Question Fitment question
20x8.5 Front5x114.3 20
20x10 Rear5x114.3 32
Would these fit I know a lot of ppl ask this but I really want to order these wheels I just want to know if it would fit and what color would you guys go on a Black G coupe here are some pics
What tires would you go?
Old Jan 5, 2011 | 12:04 PM
Sp33dY's Avatar
F20X8.5et20 24lbs R20x10et32 27 lbs R245-35-20 F285-30-20 What do you guys think????
Old Jan 5, 2011 | 01:29 PM
Sp33dY's Avatar
Oh and I really want to stretch the tires if possible not too much ( not look retarded) but a little stretch because I want to drop it with the Tanabe DF210
Old Jan 5, 2011 | 01:33 PM
Kuneff's Avatar
you do know there is a sub section dedicated to wheels and tires along with fitment questions. There is also the Master FAQ thread that gives links to all the info your asking....
Old Jan 5, 2011 | 01:46 PM
Sp33dY's Avatar
Thank you
Old Jan 5, 2011 | 02:18 PM
Sp33dY's Avatar
I cant seem to be able to figure this out. WTF how can I know if this offset will work or will I need a spacer? and what tires size is best?
Old Jan 8, 2011 | 01:16 PM
Sp33dY's Avatar
Anyone???
Old Jan 8, 2011 | 01:32 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Use this website to give you an idea of what you want.
http://rimtuck.com/thumbnails.php?ve...del=G35+coupe&
Go through the data carefully and don't just glance at it, like most people do. There are pictures as well as a chart that lists offsets, widths, and tire sizes. Compare to what you want and go from there.
Old Jan 8, 2011 | 02:03 PM
Sp33dY's Avatar
Wow thank you that helps a lot bro. But for the rear all the 20x10's have negative offset like -5, -6, and the rims I want are 32 is there any way to fit those with like a spacer or something?
Old Jan 8, 2011 | 02:23 PM
XiN's Avatar
XiN
Itasha Coupe
Yes, there is a way, you just have to do the math.
If your offset is a 32 and you add say a 25mm spacer, then do the math.
32 - 25 = 7
So your final offset would be a +7.
Old Jan 8, 2011 | 02:59 PM
Sp33dY's Avatar
Thank you very much I finally got it lol. One last question if I wanted a negative offset because I want the rims to look a bit bent in I dont know how to explain it I want like a -1 I really like patman530's look I'm sure you have seen his car would I need like a spacer 33 do they make such a size? http://www.cardomain.com/ride/2549633/2005-infiniti-g
Old Jan 8, 2011 | 04:37 PM
eurodre's Avatar
they are "bent" because of the negative camber required to fit them in
this isn't done for looks and anyone doing it soley for looks is an idiot
Old Jan 8, 2011 | 05:41 PM
XiN's Avatar
XiN
Itasha Coupe
They do not make a 33mm spacer.
From what I know, they make 5mm (V1), 10mm (V2), 15mm (V1 and V2), 20mm (V1 and V2), 25mm (V2), 30mm (V2), 35mm (V2), and 38mm (V2).
And Eurodre is correct, the reason why Pat's car looks "bent in" is because of the negative camber he is running. From the looks of it, he's probably at a -3.5 degrees of negative camber and he only does so since his offsets are in the negative.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
