will they fit?
Old Jan 9, 2011 | 12:19 PM
CJunemann's Avatar
will they fit?
Ive got a buddy offering me his SSR gt3 wheels cheap.
they are currently on his FX45
20 x 10.5 offset +43
Old Jan 9, 2011 | 12:31 PM
Pepper's Avatar
coupe? sedan?
If its for a coupe, the offset is terrible! Im not too familiar with sedan offsets.
Old Jan 9, 2011 | 12:33 PM
CJunemann's Avatar
2003 sedan, sorry.
Old Jan 9, 2011 | 12:36 PM
Pepper's Avatar
Those are pretty much the factory offsets for the 17".
Old Jan 9, 2011 | 12:41 PM
CJunemann's Avatar
hmm
Old Jan 9, 2011 | 02:00 PM
labguy94's Avatar
I am by no means wheel expert - but please do more research. The offsets are close to the stock sedan 17s but the wheel is about 3 inches wider. You most likely could get the rears to fit but the fronts (if all four corners are the same) would be huge at 10.5 inches. If I misunderstood and only the rears are at 10.5 inches then more info about the fronts would be needed.
There are a lot of wheel gurus on here - so someone will definitely be able to help. Hope you the best in your wheel search.
Old Jan 9, 2011 | 06:04 PM
the_sedan's Avatar
one guy had like 10.5's all around on his coupe...so i believe it's doable on the sedan. try to search a lil more before you make ur mind up tho
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
