Quick fitment question (possibly picking up wheels tomorrow morning)
I want to get new 19" tires in the future just wondering what size should I get.. Keep what came on the tire.. 255/35 or get bigger side wall to fill in my gap a little more such as 255/40
The tires already look huge going to a 40 sidewall is going to add nearly an inch ( .5" on each side of the wheel)
If you want to get aggressive and get into the +15 area, you need to buy coilovers or it's going to look stupid as ****.
get lower, then add spacers.
Rear
19x9.5
+35
255/35
Front
19x8.5
+35
225/40
Yeah, I agree with 4DGS completely.
But styling aside, you can go with 15mm spacers and still use 275-30 tires judging from your pictures. It will be tight, but it looks like you have a lot of room there.
I have a question for you toymachine2009. Will your current wheel setup work on your car if you did not have rolled rear fenders???
I am just curios to know because I will be getting identical setup for my sedan, but cannot get my fenders rolled anytime soon.
Should I do 15mm up front too?? Also I don't think so the shop said when I had 245/45 18" rims they said I needed fenders rolled when camber kit was installed so I assume the same for these 19s
When I had wheels those exact specs, I had 245/35 front and 265/30 rear.. It was flush with oem z revised springs.. Stech- obviously lower, you'd want to shoot for 15mm I'd say..
I plan to get coils eventually.. But just bought these new wheels so it will be a while before coils.
I just wanted them spaced out somewhat to hold me over until then especially the front because they are soo tucked in their
so I want to shoot for 15mm spacer? or +15
