Need help on my rim set up
Old Jan 27, 2011 | 12:32 AM
4DGS's Avatar
Oh and, I have +5 on 8.5 with a 265 on the back of the Z, rear fenders are untouched and I could definitely go lower offset, camber in spec.
+5 is equal to about +17 on 9.5 so I know those couple mm will fit easy.
Edit; raking is ghey
Old Jan 27, 2011 | 12:36 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
LOL Blain! what about all the coupe cats running 225/35F 245/35R setups in the aggressive thread?! that's the same amount of stagger...
Old Jan 27, 2011 | 12:39 AM
4DGS's Avatar
When stretching it goes differently, stretched tires are less noticeable when they have been gheyed. Once they are fat, you can tell.
Plus, have you seen a 285/35? That tire is a savage. Using that over a 285/30 would be silly.
Old Jan 27, 2011 | 12:43 AM
Agreed, just trying to make my point though, that it is perfectly fine for the OP to run a 285. I would never run anything that tall but for some people, it is there cup of tea.
And yes, i mount 285/35/19's on vette's all day (completely different animal, i know. but just for argument's sake)
Old Jan 27, 2011 | 12:47 AM
4DGS's Avatar
Just looks wrong lol
I would never run the same sidewall front to back unless it was within 10mm in tread or aggressively stretched.
Old Jan 27, 2011 | 12:51 AM
LaserRedG35VS's Avatar
Ok, I understand 285/35 is too much now. Reviewing these posts I've come to a conclusion of running 255/35 F and 265/35 R. So does this mean I should do -3 degrees camber all around or can I go a bit more positive. Also, I want the front tires to protect the front rim from pot wholes. Im worried more about the front cause thats where all the weight is. Will 245/40 be a good look with the 265/35 in the rear, or should I stick with the 255/35 F.
Dont forget I will be running 31mm converters all around!
Old Jan 27, 2011 | 12:56 AM
4DGS's Avatar
With which offset where?
Old Jan 27, 2011 | 12:58 AM
+45 offset Front +33 rear. I told VMR I want the Rear wheels to come out a bit more than the fronts so this is what was suggested
Old Jan 27, 2011 | 01:02 AM
4DGS's Avatar
Wait you ordered them from VMR, knowing that they are a BMW/VW bolt pattern?
Old Jan 27, 2011 | 01:05 AM
ya, thats why i got the 31mm converters. At first I was gonna buy 25mm all around but I couldn't find this specific bolt patter conversion in that size. Besides, I think it will be quite a beefy look with the 31mm's.
Old Jan 27, 2011 | 01:21 AM
4DGS's Avatar
Yea man, you should have really bought wheels in the right bolt pattern and proper true offsets.
245/40 and 265/35 would work fine.
Old Jan 27, 2011 | 01:26 AM
ok, sounds good. Last thing - what about the camber?? I want a slanted look but I dont want to go too much where my tires will be eaten away much faster.
Old Jan 27, 2011 | 01:29 AM
4DGS's Avatar
the front's you can't pull much, so when you lower it let that go natural and it should come in around 2ish if you go somewhat low.
The rear's natural camber will pretty much match the rear as well. just over 2 on say a 2" drop.
Camber for our cars pretty much goes, 1 degree for ever inch you lower the car. So if you slam it hard you could pull about -4 degrees.
Old Jan 27, 2011 | 01:38 AM
Im gonna install megan arms F&R so i will adjust both to be at about -2.1 to -2.3 not sure yet, ill figure it out. Thanks a lot man, now I know what to do when i get these on . and if you're wondering why I got VMR's, I seen this guy's thread https://g35driver.com/forums/media-s...west-look.html (I got different model wheels)
The price is amazing and the quality is pretty good. My bro has VMR, running fine for a good two years now.
Best of all, NO one has the wheels I got on a G, well I haven't seen them yet at least.
Old Feb 15, 2011 | 04:39 PM
  #30
Guys, I just came back from shop and they cut my rear fenders. The fronts though he said were already rolled and if they cut them the Mud guard protectors won't be held by anything. I'm worried that the front rims will rub- what do you guys think?? I'm dropped on eibach pro kit and I will be installing 19x9.5 wheels w/31mm spacers all around. Tire size will be 245/35/19. Will I be fine? He said I would but I don't think so!
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
BlackGee35
Jul 31, 2015 11:04 AM
multimut
Canada
Jul 26, 2015 08:43 PM
