rear fitment concern..
Old Feb 11, 2011 | 10:04 PM
mkvl127's Avatar
Originally Posted by ekrebs
Ya im just going with the full Z suspension for now which im told is an inch all around! but in the future if i go lower(coils maybe) will i need to roll for sure? or do u all think ill still be in the green?
a full z suspension will lower the sedan prob more then 2 inches..the coupe set up will lower u conservatively (less then 2 inches) a lot of people will run coupe springs and struts in the rear and do the Z suspension up front..gives it a nice drop
Old Feb 11, 2011 | 10:53 PM
ekrebs's Avatar
Can someone else confirm this? I did some searching and from what i read i was pretty sure the full Z suspension would be conservative (around an inch all around)??
Old Feb 11, 2011 | 11:04 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
350Z suspension drop.
Username: cato
https://g35driver.com/forums/5176504-post17.html
Old Feb 11, 2011 | 11:46 PM
ekrebs's Avatar
Username: cato
perfect, this is the drop im looking for, so will i need to roll the rears with the set up i have in the rear? looks like his set up was on 17's, thanks again for the reply's..
Old Feb 12, 2011 | 12:48 AM
4D05G35's Avatar
Not sure where he got his info, but full Z suspension will drop you about 1" and coupe springs will drop you about .5".
The Z/G set-up is desirable as a mild drop because the rear (G-coupe) springs drop aout .5" and the front (Z-springs) drops about 1". Most like it because the rake creates an even fender gap (rear fender is cut lower) and eliminates the "squating" look.
O.P, if they are +40mm offset you might need to do a slight roll of the fender. I ran 255/35/19's on 19x9.5's w+40 offset and they fit nice. They did rub on hard turns or big bumps, but 97% of the time it was good.... I was on G/Z springs.
Old Feb 12, 2011 | 12:55 AM
4D05G35's Avatar
Oh and BTW im running unrevised G/Z springs with tokico shocks and loving it. I started with a full Z drop, but opted for the G rear springs later on. On level ground you can see the slight rake, and the fender gaps are even...
Old Feb 12, 2011 | 12:04 PM
ekrebs's Avatar
Does the full Z set up give it a squating look?
Old Feb 12, 2011 | 02:10 PM
4D05G35's Avatar
Yes because the Z suspension will drop you about 1" front and rear. The rear wheel wells on our cars are cut a little lower than the fronts. The gap between the rear tires and fenders is less than the gap in the front. It's more noticable once the car is lowered. It isnt much, but when you have a 1.5" gap up front and a 1" gap in the rear it becomes more pronounced. Some dont mind it and others (like l) prefer an even gap front and rear. By running Coupe rear springs it increases the rear gap slightly and elimiates the "squatting" look.
https://g35driver.com/forums/brakes-...nsion-pix.html
Check out this post it will give you a good idea of what im am talking about.
Old Feb 12, 2011 | 02:49 PM
ekrebs's Avatar
Thanks, so would you agree that going with stock z shocks and z springs up front with coupe rear springs will give me a good stance and ride??
Old Feb 12, 2011 | 03:35 PM
4D05G35's Avatar
I am happy with the stance, it gives a nice subtle drop. The Z shocks/springs will firm up the ride a little bit. Iv'e never run OEM Z shocks so I cant say with certainty, but there are a lot of people who do run them and seem quite happy. From what I hear it's a nice upgrade without being overly aggressive.
I went from OEM suspension to Z springs/OEM sedan shocks to Z front/Coupe rear with tokico shocks for a Z. I am happy with the set-up.
Old Feb 12, 2011 | 05:47 PM
perm_reehal's Avatar
def drop it!
Old Feb 15, 2011 | 06:35 PM
ekrebs's Avatar
Originally Posted by perm_reehal
def drop it!
Thanks for the advise!
rezendvous420
May 31, 2020 01:26 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Soumilg
Jul 18, 2015 12:33 PM
