20x10 +35 up front on a coupe?
Old Mar 4, 2011 | 01:26 PM
JuicedAthletics's Avatar
I’m going for a different look. I have an 04 coupe with Brembos. I am dropped on Tein s-tech for the G. I want to run 20x10 +35 on all four corner. Spacers out back.
My question is if it will fit in the front. Also, what size tires? I’d rather not guess if anyone has done this before.
Old Mar 4, 2011 | 01:39 PM
4DGS's Avatar
It's been done, you'll need some spacers to get flush and recommend stagger the tires.
What wheels are they? I'm concerned with brake clearance.
Old Mar 4, 2011 | 01:53 PM
XXR 006 or 521 probably. They are strictly daily driving wheels, hence the heavy cast wheels.
And yes, the tires will be staggered. Any idea on the sizes?
Old Mar 4, 2011 | 02:28 PM
4DGS's Avatar
Ok, well you probably read the site that is wrong.
Those wheels actually only come in 20x10.5 +35 not 10.
I knew they were going to be XXRs that's why I asked.
But no worries, they will still fit, you'll just have to do a mild stretch up front to avoid a loss in handling.
I am still unsure of brake clearance, the fronts could probably see a 15 or 20mm spacer which will help clear your brakes and the rears can definitely see a 20mm spacer and rolled rear fenders.
Tires, I'd go 255/35 and 285/30
Only reason to go that wide in the front is to avoid a big stretch, but even 255 is a somewhat mild stretch.
newg37
Jul 26, 2015 09:32 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
