Project kicks wheel spacers?
Old Mar 9, 2011 | 04:21 PM
acurael's Avatar
Hey guys,
I know alot of you use the Ichiba V2 spacers on your cars from searching. Any ideas on project kicks spacers? has anyone tried them? I'm getting quoted 400 for front and rear 25mm....i was told they are good quality and a bit better than the ichiba's. I also heard that the ichiba's sometimes seize on the hub....
Should i order the ichiba's online or go with the project kicks?
advice appreciated...thanks
Old Mar 9, 2011 | 04:31 PM
4DGS's Avatar
Project kics are a superior spacer without a doubt, better hardware better lugs better quality.
That's gonna be with hub rings, price is okay. Some vendors on here could probably do better.
Old Mar 9, 2011 | 04:57 PM
acurael's Avatar
thanks....any other opinions?
I'm debating doing 25mm all the way around or 20mm in front / 25mm in back?
my car is a 06 coupe with stock 19 inch rays and not lowered
Old Mar 9, 2011 | 05:26 PM
4DGS's Avatar
I'd roll the rear fenders and do 25s and 30s.
Old Mar 9, 2011 | 06:06 PM
tragedycat's Avatar
I'd go with Ichibas, they are hubcentric. I have 10mm Project Kics spacers and have to buy their overpriced hub rings seperately. I'm probably just going to slap them on without, or trade somebody for Ichibas.
Old Mar 9, 2011 | 06:29 PM
J2S2M's Avatar
Project Kics > H&R > Ichibas
Old Mar 9, 2011 | 07:21 PM
4DGS's Avatar
Ichibas are known for ****ty studs. That's the only reason I stay away from them.
Old Mar 9, 2011 | 08:17 PM
seymore4's Avatar
m56
Project Kics is undoubtedly higher quality, you do NOT need the hubcentric rigs they sell separately.
If you're interested I can get you a full set (all four) of project kics for 250 shipped. got 15, 20, 25mm
Old Mar 9, 2011 | 11:14 PM
YT35's Avatar
project kics ftw! and i'm sure you can get a much better price than 400$ for 2 sets
Old Mar 10, 2011 | 12:45 AM
acurael's Avatar
What exactly are the hubcentric rings for? they are selling them without the rings and I was told that they are not necessary since they will fit my vehicle perfectly?
I think i might go for the project kicks then (20mm front/25mm back), they are pricey but as long as they are good quality then its fine (i'm in canada - which means everything is more expensive unfortunately). I could order online in the states but I'll probably end up paying duty anyways.
thanks for your help
Old Mar 10, 2011 | 12:50 AM
J2S2M's Avatar
Are you talkin new ones shipped?
Old Mar 10, 2011 | 02:28 AM
seymore4's Avatar
m56
yes, brand new sealed in the box, shipped
Old Mar 10, 2011 | 03:11 AM
by15vc's Avatar
I ran kics spacers back then with my oem 19's with no hubcentric rings and I had 0 issues. Don't get them, not worth the extra 120+. They should run at 125 per pair, 135 with the bigger spacers I think.
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
Albanian122
Aug 1, 2015 08:41 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
