does this look "not right"? 19x9.5 ET-20
Old Mar 10, 2011 | 05:22 PM
CandlestickPark's Avatar
ill Sedan
^That assumes he has adjustable front a-arms.
Old Mar 10, 2011 | 05:27 PM
eurodre's Avatar
if he's that low and doesn't already then oh boy
Old Mar 10, 2011 | 05:29 PM
ill Sedan
Some of us run natural camber (at least up front)...hehe
Old Mar 10, 2011 | 05:48 PM
GreenGoblin's Avatar
The goblin resurrection
I think I agree take it down to a 10mm spacer. What do you have out back?
Old Mar 10, 2011 | 06:30 PM
cungkpham's Avatar
to answer some of your questions:
-I do have the SPC front camber kit
-My tire size is 215/40/19 (i'm horrible with memorization, i think the sidewall is either 35 or 40)
-The rears are 10.5 ET +0 with 245/40/19 (again, forgot the sidewall). I want to buy new rear tires and get 225's instead.
The spacer isnt even mine. I was changing out my front brake pads and my friend had 20mm spacers in his car and told me I should just try it out for craps and giggles. After I put them on, I was like So I was debating if I should buy them off him or not. With the help of Driver, I decided Im not going to buy them and get 10mm instead.
Thanks guise!
Old Mar 10, 2011 | 06:32 PM
eurodre's Avatar
you can easily do a 225/35 the current stretch is not necessary
Old Mar 11, 2011 | 01:14 PM
Matzo Ball's Avatar
-10 with current camber would be on point. 225/35 is a good recommendation also. Any pics to compare front and rear poke?
Old Mar 11, 2011 | 05:02 PM
by15vc's Avatar
Not too much, stay with -20 and push out the rear to match. Dial in some camber and you're good.
Mine at -22 front
Old Mar 11, 2011 | 05:04 PM
Matzo Ball's Avatar
perfect stance^^ what wheels?
Old Mar 11, 2011 | 05:09 PM
vsxx
Old Mar 12, 2011 | 02:26 AM
hcag2's Avatar
Mine at -22 front
yeah, but you're slammed compared to the OP...
that's why yours looks better.
brownie
Nov 25, 2015 12:50 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
the93owner
19 Inch
Sep 23, 2015 03:03 PM
