Need new tires, don't know wheel offset...what size tire to get?
Old Apr 4, 2011 | 06:52 PM
G35BASTARD's Avatar
Hi -
I'm in need of new tires for my coupe and probably going to get the V12's but I'm not quite sure what size I should get or is recommended, specially not knowing the offset size of my wheels. When I bought them the guy mentioned they are 20x8.5 and 20x10.5, but wasn't too sure about the offset.
The wheels are iForged Retro, and they are currently wrapped in Toyo T1Rs (bought them with tires). The size of tire on them right now are - 245/35/20 & 275/30/20.
Should I keep them the same size? Or go with a different size tire? Recommendations?
Old Apr 4, 2011 | 08:10 PM
4D05G35's Avatar
The size you have are pretty typical.
If your current tires work for you and you dont plan to change anything (suspension, etc) then I would just stick with that size.
Old Apr 5, 2011 | 02:23 PM
G35BASTARD's Avatar
Well I was thinking going a little thicker on the tire. Kind of getting a little tired of feeling every bump on the road. Already bent 1 rim and had to get it repaired. But good to hear that's a commonly used size. - thanks
Old Apr 5, 2011 | 02:37 PM
4DGS's Avatar
^ then you need to buy 19s and not 20s.
Old Apr 5, 2011 | 04:52 PM
G35BASTARD's Avatar
Hmm.. decided to go with 225 35 20 & 245 35 30. I'll end up stretching the rears but I think that'll work, and save me a couple bucks. I'm planning on adding 1in. spacers as well later, hopefully the tires wont rub.
marsman328
Northern California
Aug 11, 2015 07:29 PM
Detailed Image
Jul 24, 2015 12:31 PM
realtalk21
Jul 20, 2015 09:07 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
