These offsets WILL fit the coupe - long
Old Apr 19, 2003 | 08:09 AM
BillR's Avatar
I know everyone has been asking what offset will fit, look good and not rub, etc, etc. Well here is some info:
Stock offset is:
17's 30mm (f) 33mm (r)
18's 30mm (f) 30mm(r)
The Infiniti Nismo wheels are:
18x8.5, 25mm (f)
18x9.5, 30mm (r)
I have personally installed on my coupe (non Brembo):
18x8, 40mm (f)
18x9, 40mm (r)
This combo tends to fill out the wheel wells more than stock, but still leaves the wheels too much inside the wheel wells and looks too factory, only comes out about 1/4" more than stock.
I then added 8mm spacers which made the effective offset 32mm. This helped alot to fill out the wheel wells more, but still not enough. Comes out about 5/8" more than stock. I have posted pics in the rides section (and my signature) of my car set up this way.
Last night I installed new wheels:
18x8, 20mm (f)
18x9, 25mm (r)
This set up looks JUST right. Brings the tire/wheel combo out more flush w/ lip of fender, BUT still inside. In other words, it doesn't look ghetto ish.
Tires:
Tires used on the 40mm offset wheels were:
Nitto 245/40X18 (f), 275/40X18.
I didn't like the look of the rear tires on 9" wheels. The side wall looked too high and too rounded. Kinda like a "too big of a tire on a too small rim". It also looked way different than the fronts. The fronts looked perfect.
On the new 25mm offset wheels I went with a 275/35X18 tire. That tire now looks perfect. Yes it IS slightly a smaller dia. but it now looks like it belongs.
I'll post pics later today.
BillR
tiguy99
Jul 26, 2015 01:39 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
