Tires + Fenders question
Old May 17, 2011 | 04:26 PM
g35_demon's Avatar
Hey guys I'm sorry if this was posted in the past, but I just purchased new wheels:
19x8.5 front +35
19x10 rear +35
I was wondering what tire size should I go for and would I need to roll up my fenders?
Old May 17, 2011 | 04:48 PM
GR6RR's Avatar
https://g35driver.com/forums/search.php
https://g35driver.com/forums/wheels-...-here-135.html
Old May 17, 2011 | 05:47 PM
4D05G35's Avatar
Yes a little searching would serve two purposes.
A) You would learn about our cars a bit
B) You would get the answer to your question and the ones to follow.
There is no way to answer your question with the very limited info you provided.
Do you have a coupe or sedan?
What are the wheel offsets?
Is your car lowered?
If the answer to the above question is yes, then how much is it lowered?
Old May 17, 2011 | 05:53 PM
4D05G35's Avatar
Oh and welcome to the forum, there is a lot of usefull info on here and it's a great place to learn about our cars.
Old May 17, 2011 | 10:19 PM
g35_demon's Avatar
lol, I knew that was coming up, but ya it's a 2005 coupe stock suspension. The offsets are 35
Old May 17, 2011 | 10:35 PM
4D05G35's Avatar
Were the offsets always in your first post? If so dang I missed that..
245/35/19 and 275/35/19 are a pretty common tire size. Some go with a 275/30/19 rear, but I dont like the idea of a smaller rear tire diameter.
With a +35mm offset you have nothing to worry about when it comes to rubbing. They will actuall tuck in a bit, I would recommend other wheels or some spacers. Maybe 20mm in the rear and 30 in the front.
Old May 17, 2011 | 11:06 PM
g35_demon's Avatar
Thanks for the input 4D05G35.
Old May 18, 2011 | 12:56 AM
4D05G35's Avatar
Just hope it helps.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
jjohns2711
Aug 5, 2015 08:58 AM
Soumilg
Jul 18, 2015 12:33 PM
