Tire Fitment on 19x8.5 +24, 19x9.5 +26
Old May 31, 2011 | 03:01 AM
NismoLay's Avatar
Hi all,
Thinking about picking up a set of wheels for my 05 sport coupe. They are sized 19x8.5 +23, 19x9.5 +24. I am at stock height and what tire size would be appropriate? I was thinking fronts 235/40 & rear 265/40. Any suggestion will be much appreciated. I am looking to not stretch the tires. Also will I have rubbing issues?
Old May 31, 2011 | 10:05 PM
4DGS's Avatar
245/40 and 265/35 would be ideal.
If it were me I'd do 245/35 and 275/30 thought
Old Jun 1, 2011 | 02:21 AM
NismoLay's Avatar
If I go 235 in the front and 265 in the rear would it throw off the tpms?
Old Jun 1, 2011 | 02:31 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
255/35f 275/35r.
Old Jun 1, 2011 | 02:36 AM
NismoLay's Avatar
Thanks for the replys. Can you guys tell me why you choose those setups?
Old Jun 1, 2011 | 02:42 AM
245/275 is the most common set up if you don't want stretched tires. I suggested 255/35 up front because it is closer to the overall diameter of the stock tires.
You can run 245/275 problem as well.
The 235/40/19 & 265/35/19 are rare sizes which will cost more money
Old Jun 1, 2011 | 03:20 PM
4DGS's Avatar
^ +1
275s and 245s are common to find in stock. 235 and 265s are almost always a special order.
Either set up works, neither will trip out your VDC.
Old Jun 1, 2011 | 07:16 PM
NismoLay's Avatar
If I were to go 235 and 275's will that work too? Will this setup throw off my tpms?
Old Jun 1, 2011 | 08:08 PM
235/35 will be too small up front. You can do a 235/40/19 but that is a hard to find size and i'm pretty sure only bridgestone, advan and pirelli make anything in that size which = $$$
But yes, 235/40F 275/35R will work.
jsimonk
Dec 22, 2023 03:49 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
EPG35
Aug 16, 2015 04:52 PM
