lug nuts helpppppp!!!!!!
Old Jun 5, 2011 | 06:20 PM
sallyg91's Avatar
i just bought a set of piaa rozza rims and iam looking to change the lug nuts and put extendd lug nuts does anyione now wat brand were to get them if i have to change the wheel stud ? i have no clue wats involved please let me no the size i need and were i can get them thanks
Old Jun 5, 2011 | 09:04 PM
4D05G35's Avatar
So you just want to run longer lug nuts? Check the vendor forum several of them sell what you are looking for.
Old Jun 6, 2011 | 03:08 PM
4DGS's Avatar
You only need to change wheel studs if you plan to run a spacer.
If you want lugs that stick out a little more then look in project kics R40s, they are open ended and quite a bit longer than OEM. Muteki also has a open ended lug but I can't recall the name, maybe sr48,
Old Jun 9, 2011 | 12:02 AM
DailyDrivenCoupe's Avatar
he is right on a couple of those, everyone from rays to work as well as vision motorworks and NRG and Mcgard. they all make different types of extended lugs as well as a few closed end lugs longer then the stock ones. gl on ur search
seagrasser
May 3, 2022 09:43 AM
NyCrAzY
Oct 1, 2015 09:19 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
