Wheel lug nuts missing
Old Jun 7, 2011 | 10:08 PM
achilles333's Avatar
Hi,
I recently purchased infiniti g35 coupe from private owner. After purchasing I realized two wheel lug nuts missing on driver side rear wheel. The vehicle has aftermarket rims. Enkei LSR rims. Can someone please suggest the wheel lug nuts that I can purchase. I have OEM wheel lug nuts. Will that works??
Thanks for your time!
Old Jun 8, 2011 | 02:25 AM
4DGS's Avatar
Did you buy the car certified?
If so, that's terrible to hear as it actually failed it's safety. A portion of the certification is called "nuts and fasteners" A car with 4 lugs on a 5 bolt automatically fails.
You CAN use OEM lugs if they fit the holes but buying aftermarket spline drive lug nuts would be your best bet. You local tire shop can help you out with those.
Old Jun 8, 2011 | 12:30 PM
Thanks for your input. Car isn't certified. I purchased from private owner. During purchase I missed checking all the lug nuts.
In general, does lug nuts comes along with aftermarket rim?
Old Jun 10, 2011 | 08:05 AM
EL-EE-ES's Avatar
get a set of tuner lugs, they have a tapered end to fit aftermarket wheels. oem lugs have flat ends
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
