Anyone know the specs of Ichiba's V1 spacer bolts??
Old Jun 19, 2011 | 05:54 PM
Blue Dream's Avatar
I drove ttrank's car solo
Hey all, I need to replace a couple of the bolts that came with my Ichiba 5mm V1 wheel spacers. Ichiba wants $25 for a replacement set of 5 which is highway robbery since the originals are a POS. I'm going to go to a specialty hardware store to see if I can find the correct bolts, but wanted to check to see if anyone knew the thread pitch and other specs of these before I took one to the store.
BTW these are the 4th Ichiba part I've purchased and put on the ride and all 4 have crapped out in one way or another. I will never buy another thing from Ichiba again, never.
Old Jun 19, 2011 | 06:09 PM
CandlestickPark's Avatar
ill Sedan
Sorry you've had such bad epxeriences with Ichiba products Tim. I've been running their V2 spacers for over a year now with no issues. Not 100% sure if this will help but here are the specs as posted on http://www.hrautoparts.com/ Maybe you can email them (no phone number listed on their site) to get any detailed info on the studs.
Spec:
Bolt Pattern: 5/114.3, 4/114.3, & 5/100
Center Bore: 66.2 / 56 / 60.1 / 54.1 / 67.1
Thread: 12x1.25 / 12x1.5
Longer Studs Included
Old Jun 19, 2011 | 06:22 PM
Equipped4dr's Avatar
Yeah ive had quite a few sets of v1's and v2's and never had any issues. What exactly is going on with your bolts?
Old Jun 19, 2011 | 08:25 PM
4D05G35's Avatar
12 x 1.25 x the lenght you need
14mm knurl
I would would go with an automotive grade stud.
ARP make some good ones.
http://www.conceptzperformance.com/C...5766.249.68.51
Old Jun 20, 2011 | 04:56 AM
Blue Dream's Avatar
Thanks guys. The issues I've had are:
rear camber arms-bushing in the head failed
toe bolts-threads stripped
15mm V2 spacers-nuts are super soft, rounded off a couple torquing to spec
5mm V1 spacers-stripped threads on 2 bolts
Comparing their parts side by side to other company's they are noticeably cheaper in design and quality. Put a set of SPC toe bolts and a set of Ichiba's together and you'll see what I mean. 4D that's a great link, thanks.
Old Jun 20, 2011 | 09:16 PM
4D05G35's Avatar
You're welcome.
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
prinny
Nov 22, 2015 11:07 PM
Terry_G35
Sep 10, 2015 08:17 PM
