Been searching for this for a good while now and got alot of random answers anyone know what it is exactly ..?
I believe the rims are 18"
click here to view the exact rim
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
Pretty sure they are 18 x 8 +33, 18 x 8 +30
Quote:
thanks for the quick response but I have no clue how to decode that to how I want it which is for example 275/45/20 etc etcOriginally Posted by CandlestickPark
Quote:
18" diameter x 8" wide with =33mm offsetOriginally Posted by Rizzle
18" diameter x 8" wide with 30mm offset.
225/45/18F
and 245/45/18R is what came stock I believe
225/45/18F
found out but thanks bro! Originally Posted by 4D05G35
18" diameter x 8" wide with =33mm offset18" diameter x 8" wide with 30mm offset.
225/45/18F
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
However, you're better off running 245/45X18 on all four corners for better stability and handling. Never understood why Nissan insists on running the 225s in front when the 245s work so much better?
Gary
Gary
Quote:
Gary
thnx for that infoOriginally Posted by gary c
However, you're better off running 245/45X18 on all four corners for better stability and handling. Never understood why Nissan insists on running the 225s in front when the 245s work so much better?Gary
I might be getting an 03 coupe sport automatic (wish i could get the 6MT one
) but for the price im getting it at I dont mind, and im looking into the cost of tires so far I like the Bridgestone Potenza s-04 pole position, look like they have plenty of grip and i know the g's are rwd not sure if these tires will allow me to have some sideways fun though, unless its wet conditions
.Also plan on putting on TEIN street basic coilovers, aren't the 245 front tires too wide for the drop?
