Does 295/35/18 fit
Does 295/35/18 fit
Does a 295/35/18 fit the 03's without rubbing? The car is not lowered. Is it worth the extra money compared to the 275/40/18? Which size would you guys recommend? Will the camber need adjusted for the extra width?
The offset of the wheels plays a major part in weather it rubs or not, I run 305/30 R19 with no rubbing and I am lowered. I am not sure why you want the extra width, if you need more traction or if you just like the look? I personally like wide tires so I guess it is up to you weather it is worth the extra $$$$
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
