stripped lug nut
Old Jul 29, 2011 | 08:18 PM
lung's Avatar
stripped lug nut
When i was about to sand my 19 inch rays the other day i noticed that 2 lug nuts were missing. i took the wheel off regardless, sanded it, and then proceeded to put on 2 spare lug nuts from a friend... I didn't exactly think of the possibility that the wheel studs were stripped and put the lug nuts on anyways. The next day when i went to go sand my wheels again and all of the lug nuts came off... but one. i tried to get the lug nut off by twisting it and that helped some but it still wasnt off the whole way so being the dumbass that I am, I hammered the top of the lug nut hoping that it would get it back on the threads and id be able to unscrew it.
im pretty sure i hammered the wheel stud out of the hub wheel and i have no idea how the hell to get the lug nut off now... any suggestions?
thanks for reading
Old Jul 29, 2011 | 08:32 PM
SteveBlake's Avatar
Is the wheel already off?
Old Jul 30, 2011 | 06:22 AM
lung's Avatar
No that's the trouble
Old Jul 30, 2011 | 03:10 PM
parhamm1's Avatar
lol i did basically the same thing. I'd like to hear a good answer for this too. I'm probably going to try a compact hack saw of some sort to cut the stud off behind the wheel...
Old Jul 30, 2011 | 04:55 PM
Adil_G35's Avatar
Will torching it work?
Old Jul 31, 2011 | 01:38 AM
fstrthnlfe00's Avatar
Had this happen with a lug on my old car. Drill a hole in the top of the lug and use a pair of pliers to turn it all the way out or pull it off. It will give you a hell of a lot more leverage. Then just go ahead and change the lug stud and any others that look to be worn or rusted out.
Old Jul 31, 2011 | 01:44 AM
edit: I misread. That is a solution for a stripped lug. As far as the stripped stud, if its not actually stripped and just pushed out the back of the hub, just pull on the wheel a little and get it back stuck enough to start turning it with a socket. Otherwise, get a dremel.
Old Jul 31, 2011 | 11:50 AM
lung's Avatar
unfortunately i am unhandy and i do not have access to a torch.
lung's Avatar
so you're saying that i should take off the other lugs and try to pull it back into place where i can just try and take off the stripped lug nut?
thanks
Old Jul 31, 2011 | 04:27 PM
firefox's Avatar
Yeah this happened to me last winter. Using a dremel I cut across the top of the nut. Then used a narrow chisel to go down the side of the nut. After an hour of cursing I finally got the nut to uncatch from the thread.
seagrasser
May 3, 2022 09:43 AM
NyCrAzY
Oct 1, 2015 09:19 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
