Staggered set up on Sedan (19").
Old Dec 11, 2004 | 07:29 PM
kyno777's Avatar
Hi fellow G members,
I would greatly appreciate it if you guys could give me some advice on a little situation that I have. I just purchased a staggered set of HP Evo`s 19x8.5fr & 19x9.54rr for my 2k4 G35x with 38mm offset all around. Question is will I have any problems with this set up, what size tires would you recommend ?
Your comments will be greatly appreciated. I would like to run the same set up that iLLG35 is running. Do you guys think that`s a good one.
Thanks in advance.
Patrick.
Old Dec 11, 2004 | 09:39 PM
G35Lin's Avatar
Multi-Spoked Mod
hum... why did you get +38 in the rear?? does it stick out?? Or in?
Hum.. the largest you go is 245/35/19 F and 275/30/19 or 275/35/19 in the rear.
Ed
Old Dec 11, 2004 | 10:34 PM
kenchan's Avatar
Why don't you just ask iLL35? It seems he's doing fine with his setup.
Looks real nice too.
Old Dec 11, 2004 | 11:02 PM
kyno777's Avatar
staggered set up
I ordered them I should get them on tuesday.I just want to know if that set up is ok.
Old Dec 12, 2004 | 01:31 AM
skeleton_cru's Avatar
Sedan
Sounds like you will have a problem in the rear with that offset. The front is fine.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
reaper76
Aug 5, 2015 10:13 AM
wylin
Lights
Jul 18, 2015 06:12 PM
mushu
Jul 15, 2015 03:55 PM
