spacers on aftermarket wheels
Old Aug 23, 2011 | 06:19 PM
sroks5's Avatar
I need to get either a 15mm or 20mm spacer with my aftermarket wheels. If I get the ones that have the built in studs, will those work with aftermarket wheels? Or will I have to get the ones without the built in studs and buy the extended studs?
Please help.
Old Aug 23, 2011 | 09:06 PM
4D05G35's Avatar
Check the backside of your wheels to see of they have pockets between the holes for the studs. The OE studs will protrude past the edge(face) of the spacer (with built in studs) so you need the pockets so the wheels can sit flush. If not then you will need to go with longer studs and a spacer.
Old Aug 23, 2011 | 10:37 PM
sroks5's Avatar
that is what I thought. thank you so much for the input.
Old Aug 24, 2011 | 02:43 AM
ajkVQ's Avatar
if you get the spacers with studs attached, make sure they're the right bolt pattern. don't end up with a 5x114 wheel and 5x120 studs, you'd be screwed then.
jsimonk
Dec 22, 2023 03:49 PM
tphan
Aug 31, 2015 10:45 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
BlackGee35
Jul 23, 2015 01:36 PM
