25mm spacer question
With a 25mm spacer (studs attached) would the oem studs stick out of the spacer? I am trying to figure out if I should get the spacers with the studs attached or get the spacers and extended studs.
thanks
thanks
I think the OP is asking if the OE studs will extend past the outer edge of the spacer it'self, not the nuts. Such as is the case with 15mm spacers where the OE studs are longer and protrude past the spacer.
