question for Volks 10.5 wheel all around.
Old Oct 26, 2011 | 04:21 PM
shyger85's Avatar
Okay, I got 2 sets of Volks. A set of GTS and SF challenge. Both sets are 9.5 front and 10.5 rear. I was wondering if I can use the other 10.5 barrel and put on my SF challenge? So that I can have 10.5 all around. Will this work??? Has the same amount of screws but just not sure if the holes will match up! I don't wanna take the wheels off and find out it don't fit! Any help is much appreciated. Thanks..
Old Oct 26, 2011 | 09:09 PM
HXS's Avatar
HXS
yeah, it'll work for sure if the holes match up...
Old Oct 27, 2011 | 02:47 PM
4DGS's Avatar
Volk uses a slot system on their wheels instead of a bolt hole. So 90% of the wheel faces can swap barrels. As long as they are the same diameter you should be fine.
HOWEVER, you need to take into consideration the disk sizes. If the brake clearance is different wheel to wheel then you will be changing the offset be it positively or negatively. But you need to look into that and see if the set up will work. it should be about a 7mm difference for each pad size for example, Hi disk, Lo Disk, Mid disk. So potentially a whole 21ish mm of offset change.
The 7mm is a guess I know that's what several other wheel companies do.
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
neight
Aug 3, 2015 11:27 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
