Tire Pressure Sensor Reset...
Old Oct 30, 2011 | 01:03 PM
Jiggyfingers's Avatar
My tire pressure sensor turned on. All my tires measure above 35 pounds. So its either a defective sensor or perhaps the sensor needs to be reset. Any advice or similar experiences in this area? If the sensor does need to be reset can this only be done at the dealer? If its a defective sensor what do those cost. And if the sensor has to be replaced does the sensor light just go off once you ride it for a few miles or does the light need to be reset separately?
Thanks....
Old Nov 2, 2011 | 07:04 PM
Jamie's Avatar
Me too
Old Nov 4, 2011 | 03:29 PM
flyz's Avatar
The light should go off after you drive for a bit.
Old Nov 5, 2011 | 10:42 PM
cvipgo's Avatar
Thanks....
What year is your car, TPMS sensors generally go bad (batteries die out ) after 5-7 years.
Did you rotate the tires?
Old Nov 6, 2011 | 08:27 AM
My brother works at a shop and ran a test using some type of sensor test unit from Snap On. The front left Sensor is out. Looks like I'll need a new one.
Old Nov 6, 2011 | 09:03 AM
cvipgo's Avatar
The TPMS sensor reader/programmer is what he must have used. If one has gone bad - watch other sensors will follow, so replace all 4.
Old Nov 6, 2011 | 09:20 AM
e30cabrio's Avatar
Not looking forward to this on my 06.
Old Nov 6, 2011 | 09:35 AM
cvipgo's Avatar
You won't need to replace the sensors yet- the batteries last about 7 years. May be in few years
Old Nov 6, 2011 | 09:39 AM
Texasscout's Avatar
Mine still work (05') but when I drive more than 40 minutes at highway speeds, it come on anyway.
Old Nov 6, 2011 | 09:41 AM
cvipgo's Avatar
yours are on the last leg... replace them when you change tires
Old Nov 6, 2011 | 10:59 AM
Texasscout's Avatar
Been doing that for the last four years, I don't think they are going out yet.
Old Nov 6, 2011 | 12:27 PM
e30cabrio's Avatar
I hope I have two more years.
Old Nov 8, 2011 | 08:24 PM
cvipgo's Avatar
Here's the info you all can use and decide what's wrong with your TPMS...
Old Nov 9, 2011 | 04:08 PM
Texasscout's Avatar
None of those fit mine.
Start car, comes on for a sec goes off.
Drive 45 minutes at highways speeds, comes on stays on.
Turn car off, stays off till you repeat.
If you just put around it doesn't come on.
Old Nov 9, 2011 | 04:58 PM
cvipgo's Avatar
Must be your pressure receiver unit ...
