^ Yea, me neither I have ran them at 38, 40 briefly for drag/or AutoX(I did that once) but I made sure the whole tire patch was being used and put them back to 35 before I drove home
I check them bi-weekly they hold pressure pretty well. If they are are 32 I pump them to 35, looks like Ill be keeping it at 32 or maybe 30 eek lol
Quote:
Just replaced the rear dws on my g35. Got roughly 18k out of them, ran them 33psi, never rotated(front and rear tires different size). Tire wear was exactly as you describe, outer edges still good, inner section worn almost through the D in DWS. Fronts mounted at the same time, run at the same psi, and never rotated haven't even worn through the S yet.
Not just me either apparently But they only got it on only the rears hmm.Just replaced the rear dws on my g35. Got roughly 18k out of them, ran them 33psi, never rotated(front and rear tires different size). Tire wear was exactly as you describe, outer edges still good, inner section worn almost through the D in DWS. Fronts mounted at the same time, run at the same psi, and never rotated haven't even worn through the S yet.
