Question about spacers!
Old Jan 31, 2012 | 08:27 PM
Gride650's Avatar
This is my first post! I have eibach pro street s coils on my 06 g35 coupe and I would like to add spacers to go for the "flush" look. Ive been reading around and people have been putting 20mm in front and 25mm in the rear but this would be without COILS! I am wondering what fitment would for for me. I have stock oem 19's on the car. I am wonder if I i could put 20mm in front and 25mm in rear without having my tires rub or should I roll my back fenders.
thank you!
Old Jan 31, 2012 | 09:13 PM
b2autodesigns's Avatar
20mm front and 25mm rear is a good fitment for the 19" OEM. Shouldn't have any rubbing. If you did 30mm rear's you would have rollt the fenders.
Old Feb 1, 2012 | 12:02 AM
Xet's Avatar
Xet
Depends on how far you are dropped. You probably want to roll your rears regardless. I would say 25mm front and either 25 or 30mm rear if you want a semi flush setup.
Old Feb 1, 2012 | 12:22 PM
Gride650's Avatar
Okay! Thank you for your help. I am just getting spacers until I get some rims. Once that happens I will roll my fenders. My friends told me to get 25mm all around so I was just worried bout the front rubbing. Ill have to measure later today how much I dropped it.
Old Feb 1, 2012 | 01:31 PM
VMRWheels's Avatar
The most accurate way to determine what spacer size you need would be to measure.
The spacer sizing would be different between rolled vs. stock fenders, so this would help you in either case.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
