Spacer size question.....
Old Feb 23, 2012 | 11:23 AM
Dooki3butta's Avatar
Can't decide spacer size.....
so my 03 coupe is currently dropped on 350z s-techs with a front/rear camber kit with spc shims and i want my rims to be flush.
rim size -
(F) 19x8.5 +24
(R) 19x10 +40
so the spacers im thinking are 25mm up front and 38mm rear....input? Also, im thinking about doing the rear spring mount mod because the rear isnt as low as the front. should i run a 255/35/19 in the rear?
Old Feb 23, 2012 | 05:47 PM
Anyone???
Old Feb 23, 2012 | 07:03 PM
suprasam's Avatar
The best thing I can tell you is to get a ruler and measure to where you want your wheels/tires to be and then get spacers that suit that need. Also, if you got a 19x10 in the back you can go wider on the tire unless you are looking for a stretch.
But not all tires are created equal and some my have a meatier sidewall than others.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
