19x11.0 +20 with 275/30 in the FRONT | will it clear?
Mar 4, 2012 | 03:57 PM
i'm planning to get a square set-up of 19x11.0 +20.
gonna do 275/30 fronts and 295/30 rears.
just wondering if the inside part of the wheel/tire combo will hit any part of my FRONT suspension.
i'm not worried about the rear set-up.
thanks for any help
Reply 0
Mar 5, 2012 | 09:34 AM
if my wheels weren;t out for paint, I could get a pretty close ball park estimate for you...I have 19x11+23 with 305/30/19 tires, but like I said, they are all apart getting repainted, best of luck!
Reply 0
Mar 5, 2012 | 09:49 AM
I had 10.5 +7 front wheels before and had no problems. I think chris (supreme captain) had 11 fronts before with no problems with they were lower offsets.
Reply 0
Mar 5, 2012 | 11:01 AM
thx for the help guys but i found out i need a 10-mm spacer for it to clear the strut tower.
btw, Henry, did you rub in the rear of your equip set-up? i meant 285/30 on 19x11 +8.
Reply 0
Mar 5, 2012 | 05:36 PM
Tian's running 10.5 +25 with almost -3 degrees of camber. So you will need a spacer if you're not running absolute 0 camber.
Reply 0
