question about rubbing
Old Jan 7, 2005 | 01:59 AM
RRBOY's Avatar
i've got volks 19x8.5 front & 19.9.5 rear. +23/+24 offsets. the tires are 245/35/19 front and 275/35/19. im thinking about putting on eibach springs and was wondering if i'll rub. and will i have any camber problems?
also, do eibach springs for g35 come in sportlines? i've tried to search but i was only able to see prokits available.
Old Jan 7, 2005 | 02:08 AM
g35audioman's Avatar
Chances are you will have camber problems..
do a search, you'll find out everything you need to know..
Old Jan 10, 2005 | 11:13 AM
RRBOY's Avatar
ok what do you guys recommend?
eibach springs with stock shocks. is this okay?
or should i buy shocks with it?
thanks.
Old Jan 10, 2005 | 11:51 AM
Gsedan35's Avatar
Eibachs on the coupe allow for a lot of suspension movement or weight transfer, which goes along with the low initial spring rates they use. If your willing to upgrade your shocks I most definately recommend to do that and make a better spring choice. Either RSR springs ment for the Z or Tein H-tech's also ment for the Z.
Tokico D-specs are a excellent choice and since they are double adjustable you'll be able to set your ride quality. Koni sports are also a excellent choice, but do not have the double adjustablity to effect ride quality in the same manner as the Tokicos.
INVADER_6MT
Sep 1, 2015 10:19 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
