G35 coupe on Linea Corse
Old Apr 20, 2012 | 11:45 AM
Xx AzN xX's Avatar
Hey guys so my friend is trying to sell me his 19" rims from his lexus is250. The specs of the rims are.
19x8.5/10 Linea Corse LC818 - (5x114 +30+38)
So my question is that would they fit my 03 coupe with no problem? Would i need to get hub rings or anything likes that?
http://www.wheeldude.com/catalog/pro...oducts_id=6408
Thanks in advance
Old Apr 20, 2012 | 11:58 AM
Songle6MT's Avatar
They will be pretty sunk in on a coupe...
They will fit if that's the look you are going for ( sunk in ). I'm not 100% sure if you need hub rings because it doesn't specify the hub bore on the wheels. The hub bore on the car is 66.1 though...
Old Apr 20, 2012 | 01:38 PM
Xx AzN xX's Avatar
Gotcha thanks alot. What dose the sunk look look like? I searched but i cant tell if its hella flush or sunk ect.
Old Apr 20, 2012 | 01:55 PM
Songle6MT's Avatar
This is saying you have the 18" first gen coupe wheels which are 18x8 +30
You take the front of the LC818 which is a 8.5 +30, which puts you at 6mm more aggressive in the fronts ( app. 1/4 of an inch )
The rears of the LC818 is a 10" +38 which will put you at 17mm more aggressive in the back... That equates to about 2/3 of an inch.
You can go out to your car with a ruler if you want and see where the edge of the new wheels will sit roughly if you want..
Old Mar 18, 2013 | 04:34 AM
2oo6infinitiG35's Avatar
I know this is an older thread, but did you ever buy these wheels? I actually bought the same wheels as in you link from a guy with a 2nd gen Lexus IS250. I was wondering if you bought hub rings and what size. Because mine vibrate like crazy at 80mph... but I find it odd the vibration goes away above 120mph B)
Old Mar 18, 2013 | 04:36 AM
dominate's Avatar
^ yes you need to buy hubrings
Old Mar 18, 2013 | 03:07 PM
ok I'm thinking about going with these, since plastics ones can crack easier? I saw a vendor selling plastic ones for $5 less but these seem like a great deal since they should last. http://www.z1auto.com/prodmore.asp?m...ls&prodid=4524
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Steering & Suspension
Aug 3, 2015 02:44 PM
laksjd84
Jul 24, 2015 05:12 PM
