Will these fit 04 brembo coupe
Old May 22, 2012 | 12:05 AM
one2nite's Avatar
Hey guys found these local
I have an 04 coupe w/brembo will i need to roll fenders?
Stock height ( i guess ill need to lower.. any recommendations?)
FRONT: 19x9, 5x114.3 offset 22
BACK :19x10,5 inch , 5x114.3, offset 22
Old May 22, 2012 | 02:58 AM
4DGS's Avatar
Ask the manufacture, but by the looks of it they're fake RPF1s.... The manufacture probably doesn't even know.
(if they're Enkeis though, then yes they'll clear bbk)
For those specs I'd recommend rolling the rear but you won't NEED to right away.
Old May 22, 2012 | 09:05 AM
one2nite's Avatar
I found them off craigslist used. What do you mean not right away? If i lower 2inches will i need to roll?
Thanks for your help
Old May 22, 2012 | 01:04 PM
4DGS's Avatar
Yea I'd roll it if you drop it, you probably won't rub at stock height as the car is still very high.
Ask the seller if they are legit Enkei RPF1s
Old Jun 1, 2012 | 03:13 PM
Mobydick's Avatar
That depends on what size tire you go with. Anything wider than 275 for the rears will rub. I'm running 285/35/19 and my rears rub on every dip on the road and my car is not even lowered. I had to roll my fenders.
Frankieg35
Mar 20, 2016 09:42 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
