Volk Av3 on Stock 03' Sedan
Old Jun 5, 2012 | 07:41 AM
Ottawa-G-Guy's Avatar
Hey guys,
Just wanted to double check something before I get these - will I have any fit issues using Volk av3s at 19x9.5 +22 and 8.5 +22 with 1.5in lips and 2in lips respectively? Stock 03' Sedan.
Also the Volks bolt pattern is 5 by114.3 - this will mount directly on my G correct?
Thanks
OGG
Old Jun 5, 2012 | 01:01 PM
VMRWheels's Avatar
Are your fenders completely stock as well? What tire size did you want to run?
Old Jun 5, 2012 | 01:08 PM
Fenders are stock.
Tires are mounted - 275/40/19 rear and 245/45/19 front. Would like to keep those if possible, at least through this summer.
Old Jun 5, 2012 | 01:14 PM
JaE35's Avatar
Moderator
G35 Sedan
275 40's will be huge man
Old Jun 5, 2012 | 01:15 PM
VMRWheels's Avatar
Those tire sizes are too tall for the car. I would not recommend this setup.
Old Jun 5, 2012 | 01:18 PM
JaE35's Avatar
Moderator
G35 Sedan
245 45's will be huge too lol were these wheels on an SUV?
Old Jun 5, 2012 | 01:23 PM
yea - I get that they're not exactly what I am looking for.
I want the rims, the tyres are coming with them. My issue is if I will be able to run them for a bit untill I can get new rubber on them.
I take it from the responses this might not be possible? I am not sure of the size of rubber I have on my OEMs (will not be home until this evening) but I take it these won't work?
If the rims should fit - does anyone have suggestions for rubber size?
Old Jun 5, 2012 | 01:27 PM
JaE35's Avatar
Moderator
G35 Sedan
i'm no expert but those are good offsets for the sedan...you shouldn't have a problem with those wheels with smaller tires at all
Old Jun 5, 2012 | 01:45 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The rear wheels are going to stick out on a stock suspension. You'd need a 2" drop with the natural camber to make it look good.
As for tire sizes, you can do the factory 225/40/19F 245/40/19R or you can do a 245/35/19F and 255/35/19R.
I would say go with a 275/35/19 in the rear but the offset is too aggressive even if you had a 3" drop -4 camber
Old Jun 5, 2012 | 01:47 PM
VMRWheels's Avatar
If you haven't rolled your fenders, I would do so. The rear specs are a bit aggressive compared to what we've tried before, especially with those tires. I don't think it'll work well with the tires that are on the wheels now though.
Old Jun 5, 2012 | 02:38 PM
Thanks for the replys - lots to consider.
Aestetics aside, can someone provide a layman awnswer regarding if I would be able to put that wheel/tire combo on my car as a daily driver for a little while.
I understand and apprechiate the aestetic issues I may have, and am open to constant "SUV" and "4x4" comments if I were to post pics, but I just need to figure out if this will work. Otherwise my budget will likley move me towards reps, which I would rather avoid.
Old Jun 5, 2012 | 02:51 PM
VMRWheels's Avatar
If you are not planning on doing any fender modification at all, I would not run that setup. You are likely to rub in the rear considering the tires are so tall in my opinion. Additionally, since all four tires are outside of 3% of your OEM rolling diameter, it will increase brake wear, potentially leading to brake failure.
Not the most ideal setup overall in my opinion.
Old Jun 5, 2012 | 02:59 PM
JaE35's Avatar
Moderator
G35 Sedan
this...without a drop you'd be mexi-flush in the rear lol 275 35 would look nice once dialed in
Old Jun 5, 2012 | 07:18 PM
If I went to a 18" 8.5/9.5 would that be an easier fit?
Can get a set with 235/40/18 on the rears - need suggestions on rubber if the fits going to work.
Old Jun 20, 2012 | 11:29 AM
ca18detgabby's Avatar
did you ever get these?
I have a set of 18x8 +43 all around on my G and the 19x9.5 in the rears would be awesome.
if you don't get them please lmk where I might be able to get them.
