Rubbing Fronts with 255/35/19 on Volk GTS??
Old Jun 26, 2012 | 01:21 PM
daniel3ooo's Avatar
Hey fellas,
I just put my Volk GT-S on my G35 Coupe.
I have 255/35/19 fronts and 275/35/19 on the rears. I rolled the rear fender so it doesnt rub but when I make turns on uneven pavements I can hear the front rubbing.
Now, I know the front comes pre rolled from the factory but it doesnt seem to be fully rolled flat if I remember correctly. Can I roll the front some more or could the fronts be rubbing something else like the fender liner or suspension? Should I change the tires out to 245/35/19's? Would that solve my problem?
I am lowered on KW V1 Coilovers. Both the fronts and backs are slightly tucking the tires. Originally when I lowered the fronts I had it with about a 2 finger gap and it did not rub.
Thanks in advance!
Old Jun 26, 2012 | 01:59 PM
Pepper's Avatar
I didn't rub on 255's with my GTS'. Are you running spacers? Camber settings?
Old Jun 26, 2012 | 03:24 PM
daniel3ooo's Avatar
Hey pepper thanks for the reply.
I have an SPC camber kit that came with the car that I didn't touch..should I adjust the camber a bit? I also do not have any spacers. The GTS wheels are the standard +18/+17
Old Jun 26, 2012 | 04:45 PM
4DGS's Avatar
You're rubbing on the fender liner hardware. Remove the 2-3 screws in the top of the fender and pull the clips out.
Old Jun 26, 2012 | 05:50 PM
Frankieg35's Avatar
U need 245s in the front..
Old Jun 26, 2012 | 06:57 PM
daniel3ooo's Avatar
hmm im getting a few different answers now..can anyone clarify if I can use 255's in the front? I could adjust the camber but if its rubbing inside of the fender than the camber wouldnt matter correct?
Old Jun 26, 2012 | 11:02 PM
CLEANBS's Avatar
i didnt know kws can tuck tire
pics?
and 245s will solve your problem
Old Jun 27, 2012 | 01:50 AM
4DGS's Avatar
I've run 255 up front on lower offsets.... Trust me. Remove the hardware.
Old Jun 27, 2012 | 06:41 AM
Hiro's Avatar
I just responded to a post titled "tire size question" with a similiar situation. To me I thought the 255/35 was a better choice, but maybe this is the reason most go with the 245/35's. Good to know since I have to buy tires in the next few days.
Old Jun 30, 2012 | 04:21 PM
tylerxfire's Avatar
i run 245's on the front..hard to say withouth seeing the car..u could adjust the camber in the front to run a little more negative with that kit you have or just change the tire size
Old Jul 1, 2012 | 11:38 PM
Deezflip's Avatar
+1, remove the screws first, wouldn't hurt to try and not to mention...it's free. Then give the metal tabs a little bend inward. It solved my slight rubbing issues.
If it still rubs then go make camber adjustments and pay to get an alignment.
Old Jul 1, 2012 | 11:47 PM
bluedevils95's Avatar
Maybe you can do 255/30. might help out a little bit up there.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
EPG35
Aug 16, 2015 04:52 PM
neight
Aug 3, 2015 11:27 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
