G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   245's in the front? (https://g35driver.com/forums/wheels-tires/41176-245s-front.html)
MADDD_G Jan 15, 2005 02:32 PM
245's in the front?
Hey guys,
Its time for me to change my balding tires. I was thinking. Can I run 245's all around on the G35 coupe 6MT ?
MADDD_G Jan 15, 2005 02:35 PM
anybody know what the reasonwas for infiniti putting 225's in the front?
XCELR8 Jan 15, 2005 03:03 PM
You could run 245/40-18 front and 245/45-18 rear.
MADDD_G Jan 15, 2005 04:09 PM
thank you, can we confirm this?
g35massdiamond Jan 15, 2005 04:14 PM
could you run 245/40-19 in the front?
avs007 Jan 15, 2005 07:01 PM
If you're running 19s, the proper size for the front would be 245/35-19
GReddySetGO Jan 15, 2005 07:47 PM
It really all depends on the size of your rims. I don't see how changing the profile in the rear will do much. You want to change the width in the rear since its RWD. If you have the right sized rims, I would go 245's in the front and maybe 275's in the rear?
Why not tell use what size rims you have and we can better help you choose a tire size from there.
lowrider Jan 15, 2005 09:25 PM
245/40 front and 245/45 or 255/45 rear will help reduce understeer and maintain the stagger. It's a good move. also 245/40/18s are much easier to find than 225/45/18s. This assumes stock 18" wheels.
Lou
myG35ZX Jan 15, 2005 10:08 PM
Having 245x40 upfront and 245x45 outback does/did work very well for me. The car was more neutral. Where before I would dive into a corner the front would slide a bit, after the change, the front would bite right in. The downside is that the rear could, at times, break loose. Oh the fun! :D
© 2026 MH Sub I, LLC dba Internet Brands
