245's in the front?
Old Jan 15, 2005 | 02:32 PM
MADDD_G's Avatar
245's in the front?
Hey guys,
Its time for me to change my balding tires. I was thinking. Can I run 245's all around on the G35 coupe 6MT ?
Old Jan 15, 2005 | 02:35 PM
MADDD_G's Avatar
anybody know what the reasonwas for infiniti putting 225's in the front?
Old Jan 15, 2005 | 03:03 PM
XCELR8's Avatar
You could run 245/40-18 front and 245/45-18 rear.
Old Jan 15, 2005 | 04:09 PM
MADDD_G's Avatar
thank you, can we confirm this?
Old Jan 15, 2005 | 04:14 PM
g35massdiamond's Avatar
could you run 245/40-19 in the front?
Old Jan 15, 2005 | 07:01 PM
avs007's Avatar
If you're running 19s, the proper size for the front would be 245/35-19
Old Jan 15, 2005 | 07:47 PM
GReddySetGO's Avatar
It really all depends on the size of your rims. I don't see how changing the profile in the rear will do much. You want to change the width in the rear since its RWD. If you have the right sized rims, I would go 245's in the front and maybe 275's in the rear?
Why not tell use what size rims you have and we can better help you choose a tire size from there.
Old Jan 15, 2005 | 09:25 PM
lowrider's Avatar
245/40 front and 245/45 or 255/45 rear will help reduce understeer and maintain the stagger. It's a good move. also 245/40/18s are much easier to find than 225/45/18s. This assumes stock 18" wheels.
Lou
Old Jan 15, 2005 | 10:08 PM
myG35ZX's Avatar
Having 245x40 upfront and 245x45 outback does/did work very well for me. The car was more neutral. Where before I would dive into a corner the front would slide a bit, after the change, the front would bite right in. The downside is that the rear could, at times, break loose. Oh the fun!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
