Fitment Question?
Old Sep 15, 2012 | 03:56 PM
SIR NUPE A LOT's Avatar
Fitment Question?
Car Stats: 06 Coupe, non Brembo
Will these wheels wok for the my car, and will they sit flush? Do I need spacers, fenders rolled, etc?
20x9.5 +15 (R-Disk)
20x10.5 +5 (O-Disk)
Old Sep 15, 2012 | 04:03 PM
Drew113's Avatar
Ban Hammer Expert
whether you need spacers depends on what type of look your going for
yes they will fit with the car...rear fenders will need to be rolled and you will need a 235/35 front and 255/35 rear for the tires also a camber kit for the rear
Old Sep 16, 2012 | 01:37 AM
I'm going for the flushed look. So basically these wouldn't work for me, as I don't want to have to invest in a camber kit. What offsets do you suggest for flushed look, and I also plan on giving her a mild drop as well to even out the look.
Old Sep 16, 2012 | 02:30 AM
Drew113's Avatar
Ban Hammer Expert
the camber kit is for if/when you drop the car...those are decent specs for a coupe in terms of real flushness...you will just need to stretch the tires a bit if you don't want too much negative camber
Old Sep 16, 2012 | 05:49 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
^^ He won't need to stretch with a +15, 20x9.5 in the front.
Stretching on that would just look terrible.
If you don't want to get a camber kit, then I suggest not dropping your car and leaving it stock.
Old Sep 16, 2012 | 11:05 AM
Frankieg35's Avatar
U can get a camber kit for under $500, especially if it's used..
Old Sep 16, 2012 | 12:41 PM
4DGS's Avatar
If you're broke, don't mod this car. Buy a civic to "flush"
Old Sep 18, 2012 | 02:37 PM
VMRWheels's Avatar
Camber kits are a good investment if you want your alignment to be precise or need to adjust your camber to fit your wheels.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
