Crossdrilled rotors for 03 6mt?
Old Jan 20, 2005 | 10:25 AM
DRE201's Avatar
Can anyone recommend a good set of crossdrilled rotors for this vehicle. Looking for rotors with lots of design.
Old Jan 20, 2005 | 10:42 AM
Cactus's Avatar
Somebody on here posted a link for Brembo Cross Drilled's a while back for a really good price. I will post when I get home and if I forget PM me.
Old Jan 20, 2005 | 12:38 PM
afr0puff's Avatar
Supa Dupa Moderator
What exactly do you mean by "crossdrilled?"
If you are looking to just replace the rotors and keep the stock brembo calipers, then you can only get brembro drilled, or brembo slotted. Brembo doesn't offer a combination of the two for direct replacements.
Stillen makes direct replacement rotors that are drilled and slotted.
There was another company that made direct drilled/slotted replacements, but they were expensive as hell.
Old Jan 21, 2005 | 02:19 PM
khsonic03's Avatar
I know this is not the intent of the post, but figured I would throw in my 2 cents. If you are planning on tracking with these rotors, don't get crossdrilled. At the most go slotted. Crossdrilled is ok for standard street use, however.
Old Jan 21, 2005 | 05:15 PM
GReddySetGO's Avatar
I'm going to have to agree with khsonic03 on this one. I would recommend blanks for street though. Can I ask why you want cross drilled/slotted? Is it for performance reasons or looks?
Also Stop Tech makes OEM replacement rotors I believe.
Old Jan 21, 2005 | 06:15 PM
afr0puff's Avatar
Supa Dupa Moderator
Yeah, stop Tech has OEM replacment rotors, but not if you have the 6MT. They aren't compatible with the brembo calipers.
I think performance nissan has some replacements for the 6MT.
Brembo Drilled:
Brembo Slotted:
I'm very curious to see how the brembo slotted rotors would look with the calipers.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
