rear width
Old Oct 22, 2012 | 05:19 PM
extremetoy's Avatar
rear width
how wide of a tire can you comfortably fit in the rear of an 06g without it sticking out past the quarters?
thanks
Old Oct 22, 2012 | 06:00 PM
VMRWheels's Avatar
Any other information? Tire sizing you want to run?
We've put 19x11s on the rear of coupes without any issues, but it will really depend on a few things.
Old Oct 22, 2012 | 06:19 PM
extremetoy's Avatar
sorry with a 19x10 wheel or 19x11, how much tire can you fit is what im trying to figure out... any chance of a 305 fitting?
Old Oct 23, 2012 | 02:46 AM
4DGS's Avatar
You can make a 305 fit with the right offset (roughly +25) But you need to avoid having any camber or the wheel will hit the strut.
Also keep in mind, this will be purely for aesthetics and your car will actually feel sluggish once you put that large of a tire on it.
Old Oct 23, 2012 | 11:00 AM
extremetoy's Avatar
why would it be more sluggish?
Old Oct 23, 2012 | 12:42 PM
4DGS's Avatar
Because the car has no need for a huge and heavy 305 tire.
These cars can barely spin 275s (definitely can't spin quality 275s)
Old Oct 23, 2012 | 02:12 PM
VMRWheels's Avatar
A 305 can fit on a 19x11 pretty easily. Hopefully your car can make that sized tire work though! What do you need a 305 for?
Old Oct 23, 2012 | 02:38 PM
4DGS's Avatar
230hp dawg
Old Oct 23, 2012 | 09:19 PM
extremetoy's Avatar
A supercharged ls2... prob dont need the width but i like the wider look as well.
Old Oct 24, 2012 | 09:22 AM
idrive_MD's Avatar
I have a 305 (hankook v12) on a 19x11+23 (Forgestar F14), around -3-deg camber no issues other than camber wear...I do have rolled fenders but it doesnt require it unless you run closer to a -2-deg camber range or less.
Old Oct 24, 2012 | 09:37 AM
4DGS's Avatar
Then you shouldn't have asked why would it feel more sluggish! lol
Just make sure you buy nice tires... 325 cheapo tires are as good as 265 Michelin PS2s.
You have the LS2 in the car though? Pics!!!! After seeing Edafe's LS1 build I've been dying for more vettsans.
Old Oct 24, 2012 | 10:10 AM
broke_as_ajoke's Avatar
if u want a wide tire that will work best for u is a 285.. any wider is over kill..
Old Oct 24, 2012 | 01:17 PM
VMRWheels's Avatar
Truth! Can't stress that enough.
Old Oct 24, 2012 | 11:47 PM
extremetoy's Avatar
but a cheapo 325 will be a lot better off than a cheap 265... come on, lets compare apples to apples
Thanks idrive, that gives me a lot better idea of what i have to work with!
Old Oct 25, 2012 | 12:31 PM
VMRWheels's Avatar
That's true, but if you're going to go through the extra lengths to get the power and whatnot, why not just take that last step to make sure it's all being delivered properly?
