Winter tire sets question
Old Oct 31, 2012 | 11:46 PM
sippinh2o's Avatar
Hello. I am a 2006 g35 coupe 6mt owner since april.
My car is fitted with summer tires, but with a realy cheap brand, accelera, but I had to replace front left with another brand, Nankang Ultra Sport NS-II.
anyways, I've been looking into some winter sets, and on craigslist, I came accross a normal 18 inch staggered setup for g35, and 2 17 set ups.
The first 17 inch setup is from a g35 sedan, and seems all the tires are the same size, 225/55/17.
The other set is from a 350z, but it only says 225/55/17, and not sure if its staggered set up.
MY question is, is it ok to have all same size wheels/tires, all 4 tires, for g35 coup?
and also, Im pretty sure my car is equipped with sport suspension package, would the 17 rim from 350z or g35 sedan fit my car?
Thank you in advance!
Old Nov 1, 2012 | 01:44 PM
VMRWheels's Avatar
You can run square wheel/tire fitment on your car, however I would recommend getting all four of the same brand and model tires.
Old Nov 1, 2012 | 01:48 PM
sippinh2o's Avatar
another combination
Thanks for the reply
I just found out that the 18 inch dunlop m3 sets rear pair needs to be replaced, and there is a high chance that I'd be replacing the rear pair with blizzak lm60, only because the price is so good, and the lm60's have 10/32 left making them almost new.
so in short, if I go with this combo, front pair would be dunlop m3, rear would be lm60. could you tell me if this will be ok for just normal driving?
they are both performance winter tires, and would be stock 18 staggered setup for my g35 coupe.
Old Nov 1, 2012 | 02:19 PM
VMRWheels's Avatar
People mix and match tires all the time, but I don't advocate this. If you can, invest in the same tires between front and rear.
Old Nov 1, 2012 | 05:31 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Should really run a staggered fitment to keep the VDC happy. Most common combination is 225/50-17 front 225/55-17 rear.
Old Nov 2, 2012 | 04:02 PM
G35DG's Avatar
for 18", you can go with 225/45/18 F and 245/45/18 R.......
i've also seen some people go 225/45/18 F and 225/50/18 R (narrower rear tire, better for snow traction).
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
multimut
Canada
Jul 26, 2015 08:43 PM
mushu
Jul 15, 2015 03:55 PM
