1K Budget, four 18" rims for 05 Black Sedan?
Originally Posted by Vsix
interested in the Work Emotion CR KAI most... btw, thanks for all the suggestions! I was planning to get the G35c one, but kind of risky... Are there any bad things about Work wheels? some said they would bend easily...
Just make sure you get the Emotion CR KAI, not the Emotion CR. The KAI one, uses their new pressure casting technique, which yields a stronger and lighter rim. They are about the same price.
How about one of my HP wheels for like $150 a wheel plus shipping for the 18x8s - 38mm offset - pefect for G35 Sedans (also available in 18x8/18x9 staggered size).
Three designs to choose from, Here is the link:
http://www.cardomain.com/memberpage/342829/5
hey, avs007, that is cool! Can you photoshop the wheels into gold CR KAI?
http://www.work-wheels.co.jp/wheels/...1p-2/spec.html
Thanks!!
Thanks!!
Originally Posted by avs007
Here's a photshop I did with a Black Sedan and some Work Emotion CR KAI
I like the J8's on there better but they're out of his price range. Feel free to use that image as much as you want, I relinquish my copyright, hehe.
okay... I think I should raise my budget to around 1400...
How are ADR and ACE? are they reliable? I did a search, but seems no one is using them... what other brands do u recommand? or which kind of wheels match G35 sedan?
Originally Posted by cwmizner
careful there, while some have said they don't rub, some have said they do, at +30mm offset it's VERY close...
i saw lots of ppl using coupe rims with coupe stock tires on their sedan, just want to know...what does that mean about "30mm offset is very close "
Also about the VDC problem. Some ppl say it wont work ..when you have different size of tires. Also want to know if i wanna put some aftermarket rims, what can we do to the tire pressure monitor? Some ppl just ignore it so the light will be always on, but i dont want to do that. Can any one help??
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
BlackGee35
Jul 23, 2015 01:36 PM
