avant garde m510 advice...
Old Feb 3, 2013 | 01:53 PM
cardG35x's Avatar
I am looking to purchase the avant garde M510 19x8.5 or 19x9.5 for my 2008 G35xs. Currently I have the stock G35s rims 18x8 non staggerred with no suspension mods. I plan on running the non staggered due to the VDC on the AWD. Which size rim do you recommend running on all four corners? What tire size do you recommend? I am looking for a more aggressive look than the stock S rims.
Also - Any more rim recommendations?
Old Feb 3, 2013 | 04:38 PM
mkvl127's Avatar
i have advant garde m310 in satin black also in a 19x8.5 and 19x9.5 and i am also awd...im running a
245/40/19 in front and 275/35/19 in the rear..perfect tire sizes to not mess with the awd and vdc and has a decent side wall so you dont need to worry about pot holes too much..sidewall is perfect for my taste. you can google tire calculator and it will show u the specs of the tire sizes. i have the hankook ventus v12 tires also..great tires and the cheapest choice basically..when ur getting 19s tires arent cheap..on the offset i have a +30 in rear with -3 degree camber (spc camber kit) and in front i have a +20 offset with -2 and change..the front is natural camber from lowering the car..im on bc coils..if u dont plan on lowering ull need higher offsets then i have..but if u do plan to lower get ur offsets accoording to ur drop on how u want the car to look..id lower the car first before choosing rims
Old Feb 4, 2013 | 01:21 PM
cardG35x's Avatar
So you think I could run 19x8.5 +40 offset all the way around? Would this give a more aggressive look than stock 18x8 +40? I am not sure if I want to lower the car since it is my daily driver for ride quality.
Do you have any photos you could share?
Old Feb 5, 2013 | 07:19 PM
mkvl127's Avatar
the 19x8.5 +40 is only going to be .5 inches outward towards ur fender..maybe a 19x9.5 +40 so your an inch closer to the fender for more of a flush look..when i was choosing my rim and tire specs i looked at tons of threads on here of other peoples set ups and to find what i want which is aggressive without a stretched tire and functional..i have a first gen sedan so your car can take a more aggressive set up without as much neg camber..at stock ride height id maybe do a lower offset..i dont have much experience with fitment on the 2nd gen sedans...and y not go staggered like u were first asking about?
heres my photobucket with some pics of my car..the rear has -3 degrees camber,,,(im dropped prob 4inches)
(2 of the pics was before my alignment thats y the rear is poking soo much and theres so much gap)
http://s1099.beta.photobucket.com/us...27/library/g35
jsimonk
Dec 22, 2023 03:49 PM
phantomg35coupe
Sep 7, 2012 12:41 PM
zoop425
Apr 15, 2011 12:22 PM
