FS[Canada]: H&R 25mm wheel spacers
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
I am selling a set of used H&R 25mm hubcentric wheel spacers. Included are 2 sets, 4 spacers and 20 lugs nuts.
These H&R spacers will give you the performance look and handling by pushing your wheels out to fill out the wheel wells and making it flush with the fender. By widening your track, you get better handling and performance in all weather conditions as well as getting that aggresive sporty look.
These spacers are authentic H&R Wheel Spacers which are made in Germany. H&R Spacers are very light and anodized for durability. They are designed specifically for each vehicle and also easy to install. Adding wheel spacers is one of the most cost effective bolt on enhancements you can do to your car.
These Spacers feature a ‘perfect fit’ hubcentric design that makes the spacer function as a precise extension of the axle hub, thereby guaranteeing precision wheel fitment.
Benefits:
Improve wheel and tire spacing in fender
Better handling
Increased safety
Fix brake caliper clearance issues
Add inner fender and suspension clearance
Part #: 5065662-Nissan
Bolt Pattern: 5x114.3
Center Bore: 66.2
Bolt/Stud: Stud
Thread Type: 12x1.25
Spacer Type: DRM
Width: 25mm
Fits:
Nissan 350Z (2003-08)
Nissan 350Z Roadster, Typ Z33 (2004-09)
Infiniti G35 (2003-07)
I am told they will also fit:
Nissan 240SX, Typ S14 (1995-98)
Nissan 300ZX (1987-96)
Nissan Maxima, Typ A32 (1995-99)
Nissan Maxima, Typ A33 (2000-03)
Nissan Maxima, Typ A34 (2004-08)
Nissan Murano, Typ Z50 (2003-07)
Nissan Sentra SE-R spec V (2001-08)
Infiniti fx35 / fx45 (2003-07)
Infiniti I30 / I35 (1996-2003)
Infiniti j30 (1993-97)
Infiniti Q45 (2002-2003)
Condition: used, in great shape, have some corrosion from rotors on them but is not seen once installed. (see pics)
These sell new on ebay for $150 per set plus Shipping, to Canada is between $35 and $75 per set. The total shipped would be between $370 - $450 plus taxes, duty and brokerage. For Ontario the total would be between $440 - $530 plus brokerage.
On the H&R site they also sell for $150 per set, shipping is unknown.
BEFORE:
AFTER:
BEFORE:
AFTER:
Benefits:
Better handling
Increased safety
Center Bore: 66.2
Bolt/Stud: Stud
Spacer Type: DRM
Width: 25mm
Fits:
BEFORE:
AFTER:
BEFORE:
AFTER:
