HELP with tire fitment
OK guys, here's the dilemma. I bought a set of TSW Thruxtons in 18 X 8 with a +36 offset from Tire rack (being told this was the proper size) I put 245/45-18 Nitto 555's. When they arrived I put them on and they looked pretty close to the outside but not past the edge of the fenders. I then bought a set of Tein coilover and am ready to install them, but you guessed it, the tires will rub. Rather than call it a day (I can't return them after driving on them) I was thinking of switching to a 235/40-18 tire for little extra room. This tire is about an inch lower and therefore will be off by about 3%. Any one run a tire a little short like this? Any feedback?
Thanks for your time.
We have member's that have 245/40-18's with 18x8 rims on 35mm offsets without any problems with rubbing. But a 245/45-18 tire is taller, this does have a negitive effect on clearances because since it's taller it moves the tire closer to the fender lips, really it's the rear that matter. HOWEVER, Enkei did a fitment test on the sedan and used a 18x9 rim with a 38mm offset and a 245/45-18 tire and they had 2mm of clearance from the rear fender lip. A 18x9 rim with the same offset moves the tire 13 additional mm outwards and inwards.
I would look at your rims and see what offset they are stamped with.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
