Wheel Experts Step Inside
Old Jan 29, 2005 | 01:06 PM
Wingsprint's Avatar
I have a 05' coupe with factory 18" wheels and stock suspension. I am getting ready to buy a set of Eneki PK6, 8.5 in the front and 9.5 in the rear The front offset is 24mm and the rear is 25mm. I will be using 245/40 in the front and 275/40 in the rear. I have seen this exact setup on a 350Z and it looked perfect.
Will this setup fit, with no rubbing? and will the tires be fairly flush with the fenders?
I have done two weeks of research on this and other sites. I have never owned a car with so many formulas of offsets.
Thanks in advance!
Old Jan 29, 2005 | 04:31 PM
Wingsprint's Avatar
Anyone?
Old Jan 30, 2005 | 07:41 AM
Wingsprint's Avatar
Unhappy
Here is a picture of the wheels... Almost 60 views and no one knows is if this set up will work?
Old Jan 30, 2005 | 11:14 AM
1nate7's Avatar
Looks like a perfect fit to me. Offsets are good and tire sizes are correct. I don't think the wheels/tires will be exactly flush with the fender, but it will look much more aggressive than stock. Its a nice looking, lightweight wheel. Go for it!
Old Jan 30, 2005 | 04:10 PM
Wingsprint's Avatar
Thanks!
It is really difficult to find the proper setup for these cars.
Old Jan 30, 2005 | 05:50 PM
kenchan's Avatar
25mm is more than enough to get it close to the fender. A lot of the cars
I see here using 19-22mm offsets might be flush to the fender at the top but
the tires stick out the back due to the toe-in. Whether you call that a good
fit or not is really up to your preference.
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
