Inner Tire Wear and Flipping Tire Sides
Old Jul 3, 2013 | 04:20 PM
iceguju's Avatar
Hello all and Happy 4th of July! I recently just noticed that my inner rear tires (275/30/20) are worn down heavily. I saw this when I was doing my differential fluid change. The middle and outer edge of the tire have a great deal of thread left on them. I have put about 17k miles on these tires. My tires sound pretty noisey but after making the camber more positive with an alignment (1.5 months ago) the noise went down maybe 50%. Am I able to unmount the rear tires and flip the sides so I can leave the worn out thread towards the outer edge? Or should I purchase a new set of rear tires? I wonder if I can get another 5k miles out of these tires with flipping them before I put the OEM wheels on for the winter. Thanks for your help.
Old Jul 3, 2013 | 05:44 PM
LoSt180's Avatar
Flipped my rears a month ago for same reason. Should get them to last a little bit longer.
Old Jul 3, 2013 | 08:32 PM
Knightstiq's Avatar
I have heard stories of stretching belts and safety issues when flipping worn tires like you have described. I would consult with your local tire shop for advice before flipping. I know you just want to stretch a buck and I can't blame you, but safety first.
Old Jul 3, 2013 | 08:46 PM
KrazySouthG35's Avatar
I flip mine when they get bald considering the outside of the tire barely touched the ground unless you're turning lol. I've never had an issue
Old Jul 11, 2013 | 10:20 AM
MikeDG's Avatar
I've flipped my rears and fronts many times also without problems. In order to do this your tire must have a symmetrical tread pattern. Asymmetrical tires should not be flipped.
Old Jul 11, 2013 | 10:08 PM
JKL1031's Avatar
how much camber are you guys running that have to flip tires?
Old Jul 11, 2013 | 10:15 PM
Even stock ride height has enough camber to wear out the inside before the rest...
Old Jul 13, 2013 | 03:19 PM
JC-RH's Avatar
Does anyone know of a shop that flips tires in the Miami area? Called a bunch of places without any luck.
Old Jul 13, 2013 | 04:38 PM
JKL1031's Avatar
any shop with a tire machine should. if they give u hell say "put the damn front left tire on the front right, and visa versa,, DO IT!!"
Old Jul 13, 2013 | 10:42 PM
Frankieg35's Avatar
They probably think u are messing with them if u are asking them to flip your tires.. lol Any tire shop can take the tires off and remount them..
Old Jul 13, 2013 | 10:46 PM
WhosUrBuddiee's Avatar
Fix camber and get new tires.
Old Jul 13, 2013 | 10:54 PM
JC-RH's Avatar
I think they are saying no because they see it as a liability. I get an alignment done every 4 months (I have an alignment plan), but my tires are showing slight wear after about 15k miles. I'm just trying to get the most out of them.
Old Jul 13, 2013 | 11:22 PM
It is a liability and safety issue. Shops are not allowed to mount tires under a certain thread depth. 2/32 of an inch is the minimum allowed tread depth in almost all states. If a shop mounts a tire below that depth, they are liable. Most chain shops will not do it. Best bet is to try a smaller local shop.
Old Jul 14, 2013 | 12:10 AM
Frankieg35's Avatar
If your tires have 2/32 of tread left then why would u flip them.. lol Just buy some new tires..
Old Aug 15, 2013 | 10:31 PM
wallofgrath's Avatar
I just bought 1 used tire on ebay for $70
