New tires installed, now SLIP+VDC+ABS lights
Old Aug 6, 2013 | 09:23 AM
GraphiteGSdn's Avatar
Guys,
Just had tires installed minutes ago and as I exited the shop I felt the ABS actuator kick in twice. Then the lights. Did they come on because the tires are mismatched?
Front, new: 235/40/18
Rear: old: 245/45/18
The answer might be obvious but I just want to make sure. If so, this will be an expensive lesson. Grrrrr
Update: I know the lights can come on when the brake pads are low and thus forces more fluid in from the reservoir. Pads are near the end of life and fluid is just below max.
I am wondering if its actually the pads or the tires since the light came on as I was leaving the tire shop. Could it be coincidence?
Thanks
Old Aug 6, 2013 | 11:43 AM
GTLAW's Avatar
YEP! The car does not like old tires mixed. MY GF coupe did the same thing, her tires needed to be replaced and the front was worn out. So the slip light and brake like keeps coming on and off.
So you need to replace the back to correct it.
Old Aug 6, 2013 | 11:50 AM
ItsA..Gthing's Avatar
Its the difference in sidewall height..supposed to be 45 all the way around...So wheel sensors are reading them at different speeds causing the abs to kick in when braking....And at hwy speeds all the lights come on..Why did you not go with the recommended 225/45/18 for front?
Old Aug 6, 2013 | 12:34 PM
Thanks for confirming what I suspected. Great explanation. I had the stock size and should have replaced with the same. I went with the 235/40/18 so that I would have more clearance if I lower but the difference is negligible. Dumb move on my part.
I doubt the tire shop will do anything for me. Other than selling these at a loss more than likely and getting the correct size, changing the rears to a 40 series (255/40/18?) might be my best bet.
Old Aug 6, 2013 | 03:30 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yup, tire diameters are off. Nothing wider than the 245's will really fit right on the rear. I'd go oe sizes to keep all happy.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
attarday
Jul 15, 2015 04:03 PM
