Staggered set up on Sedan (19").
Hey guys quick ? for you.
Is it possible to run a staggered set up on the X. Your comments would be greatly appreciated. See the way I look at it is that the X runs 100% rwd most of the time unless a slip occurs then the AWD kicks in so there really shouldn`t be a problem if one were to go with a staggered set up right.
The drivers manual states:
CAUTION
Always use tires of the same size, brand, construction (bias, bias belted, or radial), and tread pattern on all four wheels. Failure to do so may result in a circumference difference between tires on the front and rear axles which will cause excessive tire wear and may damage the transmission, transfer case and differential gears (AWD models).
Not good...
CAUTION
Not good...
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
