anyone run a specific air pressure
Old Jan 21, 2014 | 10:36 PM
3000vr4tt's Avatar
the guys on the 3000gt forum used to run a 30psi infront 35 in rear for the awd guys..any1 with g35x care to chime in?DOMO
Old Jan 21, 2014 | 10:55 PM
Gman56's Avatar
I run 35psi all four corners on my 05X.
Old Jan 21, 2014 | 11:56 PM
totopo's Avatar
It depends on what tire you run. Remember, if you are driving more than like a mile to get to a pump to add air, subtract about 4 psi from what you are reading to roughly guesstimate your cold pressures. Also remember your hot pressures can be as much as 10psi over your cold pressure, so don't push the limits printed on the sidewall of your tire.
Old Jan 22, 2014 | 01:31 AM
bigc's Avatar
Wings Nation
35psi at each corner for normal driving
32psi in the rears when I want to drive in maniac mode
25-28psi in the rears at the drag strip (still experimenting with this though)
Old Jan 22, 2014 | 10:40 PM
3000vr4tt's Avatar
cool thanks for the info guys
Old Jan 23, 2014 | 02:40 AM
HenryLee's Avatar
I hyperinflate and run 40 psi on all 4 tires. Never had any problems.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
mtlruss
Dec 20, 2015 01:51 PM
willdogs
Dec 8, 2015 11:32 AM
RA102223
Aug 15, 2015 09:24 PM
ZacDesu
Jul 14, 2015 11:13 PM
