Why do my aftermarket wheels have 2 valve stems?
Old Sep 30, 2014 | 05:11 PM
kchar92's Avatar
Just got a set of new wheels put on. And while I was cleaning them I noticed that there are 2 valve stems.. One of course on the outside, and one and the inside of the wheel. Can someone explain what the other valve stem is for?
Old Sep 30, 2014 | 09:36 PM
CARMA_626's Avatar
On some racing wheels, they use two valve stems so you can inflate/deflate the tire while a pressure gauge is connected to the second valve stem. So it could be for that.
Old Sep 30, 2014 | 10:17 PM
Urbanengineer's Avatar
What's the brand of your wheels? I'm guessing one thing with at least two pieces?
Old Sep 30, 2014 | 10:26 PM
UCIMAplaya2's Avatar
yea multiple piece wheels often do. However I saw a set of one piece wheels yesterday that were new on display at a shop. They had a sticker indicating that the one that faces to the inside edge is for use with OEM tire pressure monitoring sensors. Basically the geometry of the wheel didn't allow a TPMS to fit in the normal location so they stuck that one out the backside to allow for pressure monitoring and you use a regular valve stem to inflate the tire in the normal location. The sticker just said that if you don't have TPMS to just install a second valve stem in that location. So it could just be that.
Old Oct 1, 2014 | 03:26 PM
GetYourWheels's Avatar
The Enkei NT03 has 2 valve stems, and as mentioned above, its so you can measure the pressure with a gauge while you fill it up (track wheels), or just inflate/deflate them quicker using both valves at the same time.
When I had the NT03s on my car that was the #1 question anyone ever had about it, haha
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
BlackGee35
Jul 23, 2015 01:36 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
